Terrain changes not saved at certain tiles
futosz
Hi!
I noticed, TSRE5 does not save terrain changes (altitude) at certain tiles. Only .t file was saved with new timestamp but unaltered content, raw files are untouched. I attached a sample tile, log and settings.txt, altough I found no error in logs (just unknown token 282 at different tiles). I tried it with TSRE5 0.699.1, 0.698.1 with the same output.
Could you look at it?
Thank you for your help in advance.
t.zip
(249.52 KiB) Downloaded 1497 times
Check write permissions for these files, try enabling terrain QT in settings.txt
futosz
Hi!
I got it, that damn Avast blocked saving *.raw files silently of TSRE :x . I add an exception and it looks fine now. I hope it does not cause off-sync tiles...
Altough, I realized TSRE saves tdb, rdb, tit and rit every time, even if I did not change anything in track database, not even select an item. Probably TSRE does not notice tdb changes?
