Activity not showing Static Consits
Posted: 23 Sep 2019, 21:18
by bootednancy
Greetings:
I am still having the same problem as I did once before, and don't know how to stop or solve it.
Route: Thames Trent version 3
Activity: Derby to Nottingham (local passenger train)
TSRE5: version 0.65792 x 32
I have put 3 static consist in the area of Nottingham station, and they appear fine with no error messages in the Consist Editor or Route Editor as shown in photo #1.
The 3 consists are recorded in the ACT file as in photo #2
When I get to Nottingham station where the activity ends, NONE of the 3 consist are there in photo #3
This is making me nuts that the consist will not appear and I can not figure out why??? Any help or cure for this is appreciated.
Thank you
Doug
TSRE5_Route Editor.JPG (73.91 KiB) Viewed 9180 times
Re: Activity not showing Static Consits
Posted: 23 Sep 2019, 21:35
Thanks for more info.
Does these consists are present in TSRE after save and reload?
If yes, then OR log would be useful.
Posted: 24 Sep 2019, 03:45
by bootednancy
Yes, the consists I previously placed in TSRE will reload there the next time I open the Editor and go to that loacation
Be glad to give you the Log, but Can't attach ........your program says file extension OpenRails Log.txt is invalid???
Thank you
Doug
Posted: 24 Sep 2019, 11:16
Use some file sharing website, for example this one:
https://gofile.io/?t=uploadFiles
Posted: 25 Sep 2019, 03:17
by bootednancy
The file has been uploaded to GOfile as you suggested, and was able to get the Txt file uploaded as a IP file on this page
Thank you
Doug
