Problem with platform markers
at the very bottom of the page
						Just remove it using new version and place new one.
Check your route for errors using new window.
Cant remove it  because editor crashes when selecting the platform marker.  When checking with the new error checker I don't get the requester  for the "TDB Error" but the error check shows an error connected with the platform marker:
Object 'platfrom' referenced trackitem has wrong type.
Indeed, there may be a problem with selecting it.
Check this version if you can select it now: http://koniec.org/tsre5/data/TSRE5_v0.698.1.exe
Yes, with 689.1 I can delete the rogue platform. I've still got some more diverse errors with the errorcheck function, so how can I go the the TDB Error check to convert route database to current global?
Btw. I'm very glad to see, that you haven't abandonded your superb RE, many thanks for your efforts.
You don't need it if you didn't see howhow can I go the the TDB Error check to convert route database to current global?
In this version you need to have basic experience with TDB names to fix these errors, but in most cases you have to delete some objects.
Until these errors are no problem for OR/TSRE you can ignore them.
