White route screen
Manuel18
A friend of mine is facing a issue with TSRE5.
He is using a laptop without problem and then some days after is facing a white screen an no objects ,track db lines are present. It's just a white space with nothing.
This error repeats like 500times or more
QOpenGLShader::link: ERROR: Definition for "void main()" not found.
[I] workingDir "C:/Users/Gabriel/Videos/TRE5 Editor de rutas"
[I] "settings.txt"
[I] devicePixelRatio 1
[E] setGeometry: Unable to set geometry 15x13+363+124 on QWidgetWindow/'QLabelClassWindow'. Resulting geometry:  120x13+363+124 (frame: 8, 31, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 0x0, maximum size: 16777215x16777215).
[I] "tsre_appdata/0.697/procedural/shapetemplates.dat"  shape definition file not exist
[I] ok
[I] "MLte"
[I] # Load Route
[I] # TRK file:  "C:\\Program Files\\Open Rails/routes/MLte/MLte.trk"
[I] #TRK tr_routefile - undefined token:  "ortsswitchsmsnumber"
[I] MSTS Geo Projection
[I] Wczytywanie pliku env:  "C:\\Program Files\\Open Rails/routes/MLte/ENVFILES/editor.env"
[I] "C:\\Program Files\\Open Rails/routes/MLte/ENVFILES/editor.env"
[I] #world - undefined token:  "world_fog_distance"
[I] #world - undefined token:  "world_sky"
[I] #world_water_layers - undefined token:  "world_water_terrain_patch_map"
[I] #world_water_layers - undefined token:  "world_water_wave_height"
[I] #world_water_layers - undefined token:  "world_water_wave_speed"
[I] #world_anim_shader - undefined token:  "world_anim_shader_frames"
[I] #world_anim_shader - undefined token:  "terrain_uvcalcs"
[I] #world_anim_shader - undefined token:  "world_anim_shader_framelen"
[I] #world_water_layer - undefined token:  "world_water_layer_sky_reflection"
[I] #world - undefined token:  "world_wind"
[I] 4
[I] -1
[I] "C:\\Program Files\\Open Rails/routes/MLte/envfiles/textures/waterbot.ace"
[I] -0.5
[I] "C:\\Program Files\\Open Rails/routes/MLte/envfiles/textures/watermid.ace"
[I] 0
[I] "C:\\Program Files\\Open Rails/routes/MLte/envfiles/textures/watertop.ace"
[I] 0
[I] "C:\\Program Files\\Open Rails/routes/MLte/envfiles/textures/test.ace"
[I] "mlte"
[I] "C:\\Program Files\\Open Rails/global/tsection.dat"
[I] TsectionDAT:  40000   40000
[I] "C:\\Program Files\\Open Rails/routes/MLte/tsection.dat"
[I] Wczytywanie pliku tdb:  "C:\\Program Files\\Open Rails/routes/MLte/mlte.tdb"
[I] TDB TrackNodes count  459
[I] "C:\\Program Files\\Open Rails/routes/MLte/mlte.tit"
[I] "C:\\Program Files\\Open Rails/routes/MLte/speedpost.dat"
[I] speedpost.dat!
[I] #speedpost_set - undefined token:  "restricted_shape"
[I] #speedpost_set - undefined token:  "end_restricted_shape"
[I] "C:\\Program Files\\Open Rails/routes/MLte/sigcfg.dat"
[I] sigcfg!
[I] #sigcfg.dat - undefined token:  "scriptfiles"
[I] Wczytywanie pliku tdb:  "C:\\Program Files\\Open Rails/routes/MLte/mlte.rdb"
[I] TDB TrackNodes count  30
[I] Wczytywanie pliku ref:  "C:\\Program Files\\Open Rails/routes/MLte/mlte.ref"
[I] "C:\\Program Files\\Open Rails/routes/MLte/mlte.ref"
[I] "C:\\Program Files\\Open Rails/routes/MLte/addons"
[I] # No Addons
[I] "C:\\Program Files\\Open Rails/routes/MLte/blank.mkr"
[I] "C:\\Program Files\\Open Rails/routes/MLte/L2.mkr"
[I] "C:\\Program Files\\Open Rails/routes/MLte/MLte.mkr"
[I] Nowy  0  path:  "c:/program files/open rails/routes/mlte/paths/101.pat"
[I] "c:/program files/open rails/routes/mlte/paths/101.pat"
[I] Nowy  1  path:  "c:/program files/open rails/routes/mlte/paths/104.pat"
[I] "c:/program files/open rails/routes/mlte/paths/104.pat"
[I] Nowy  2  path:  "c:/program files/open rails/routes/mlte/paths/106.pat"
[I] "c:/program files/open rails/routes/mlte/paths/106.pat"
[I] Nowy  3  path:  "c:/program files/open rails/routes/mlte/paths/107.pat"
[I] "c:/program files/open rails/routes/mlte/paths/107.pat"
[I] Nowy  4  path:  "c:/program files/open rails/routes/mlte/paths/113.pat"
[I] "c:/program files/open rails/routes/mlte/paths/113.pat"
[I] Nowy  5  path:  "c:/program files/open rails/routes/mlte/paths/114.pat"
[I] "c:/program files/open rails/routes/mlte/paths/114.pat"
[I] Nowy  6  path:  "c:/program files/open rails/routes/mlte/paths/116.pat"
[I] "c:/program files/open rails/routes/mlte/paths/116.pat"
[I] Nowy  7  path:  "c:/program files/open rails/routes/mlte/paths/117.pat"
[I] "c:/program files/open rails/routes/mlte/paths/117.pat"
[I] Nowy  8  path:  "c:/program files/open rails/routes/mlte/paths/125.pat"
[I] "c:/program files/open rails/routes/mlte/paths/125.pat"
[I] Nowy  9  path:  "c:/program files/open rails/routes/mlte/paths/13.pat"
[I] "c:/program files/open rails/routes/mlte/paths/13.pat"
[I] Nowy  10  path:  "c:/program files/open rails/routes/mlte/paths/131.pat"
[I] "c:/program files/open rails/routes/mlte/paths/131.pat"
[I] Nowy  11  path:  "c:/program files/open rails/routes/mlte/paths/133.pat"
[I] "c:/program files/open rails/routes/mlte/paths/133.pat"
[I] Nowy  12  path:  "c:/program files/open rails/routes/mlte/paths/134.pat"
[I] "c:/program files/open rails/routes/mlte/paths/134.pat"
[I] Nowy  13  path:  "c:/program files/open rails/routes/mlte/paths/135.pat"
[I] "c:/program files/open rails/routes/mlte/paths/135.pat"
[I] Nowy  14  path:  "c:/program files/open rails/routes/mlte/paths/136.pat"
[I] "c:/program files/open rails/routes/mlte/paths/136.pat"
[I] Nowy  15  path:  "c:/program files/open rails/routes/mlte/paths/139.pat"
[I] "c:/program files/open rails/routes/mlte/paths/139.pat"
[I] Nowy  16  path:  "c:/program files/open rails/routes/mlte/paths/141.pat"
[I] "c:/program files/open rails/routes/mlte/paths/141.pat"
[I] Nowy  17  path:  "c:/program files/open rails/routes/mlte/paths/142.pat"
[I] "c:/program files/open rails/routes/mlte/paths/142.pat"
[I] Nowy  18  path:  "c:/program files/open rails/routes/mlte/paths/16.pat"
[I] "c:/program files/open rails/routes/mlte/paths/16.pat"
[I] Nowy  19  path:  "c:/program files/open rails/routes/mlte/paths/161.pat"
[I] "c:/program files/open rails/routes/mlte/paths/161.pat"
[I] Nowy  20  path:  "c:/program files/open rails/routes/mlte/paths/169.pat"
[I] "c:/program files/open rails/routes/mlte/paths/169.pat"
[I] Nowy  21  path:  "c:/program files/open rails/routes/mlte/paths/171.pat"
[I] "c:/program files/open rails/routes/mlte/paths/171.pat"
[I] Nowy  22  path:  "c:/program files/open rails/routes/mlte/paths/178.pat"
[I] "c:/program files/open rails/routes/mlte/paths/178.pat"
[I] Nowy  23  path:  "c:/program files/open rails/routes/mlte/paths/183.pat"
[I] "c:/program files/open rails/routes/mlte/paths/183.pat"
[I] Nowy  24  path:  "c:/program files/open rails/routes/mlte/paths/188.pat"
[I] "c:/program files/open rails/routes/mlte/paths/188.pat"
[I] Nowy  25  path:  "c:/program files/open rails/routes/mlte/paths/19.pat"
[I] "c:/program files/open rails/routes/mlte/paths/19.pat"
[I] Nowy  26  path:  "c:/program files/open rails/routes/mlte/paths/192.pat"
[I] "c:/program files/open rails/routes/mlte/paths/192.pat"
[I] Nowy  27  path:  "c:/program files/open rails/routes/mlte/paths/198.pat"
[I] "c:/program files/open rails/routes/mlte/paths/198.pat"
[I] Nowy  28  path:  "c:/program files/open rails/routes/mlte/paths/200.pat"
[I] "c:/program files/open rails/routes/mlte/paths/200.pat"
[I] Nowy  29  path:  "c:/program files/open rails/routes/mlte/paths/203.pat"
[I] "c:/program files/open rails/routes/mlte/paths/203.pat"
[I] Nowy  30  path:  "c:/program files/open rails/routes/mlte/paths/204.pat"
[I] "c:/program files/open rails/routes/mlte/paths/204.pat"
[I] Nowy  31  path:  "c:/program files/open rails/routes/mlte/paths/205.pat"
[I] "c:/program files/open rails/routes/mlte/paths/205.pat"
[I] Nowy  32  path:  "c:/program files/open rails/routes/mlte/paths/21.pat"
[I] "c:/program files/open rails/routes/mlte/paths/21.pat"
[I] Nowy  33  path:  "c:/program files/open rails/routes/mlte/paths/215.pat"
[I] "c:/program files/open rails/routes/mlte/paths/215.pat"
[I] Nowy  34  path:  "c:/program files/open rails/routes/mlte/paths/228.pat"
[I] "c:/program files/open rails/routes/mlte/paths/228.pat"
[I] Nowy  35  path:  "c:/program files/open rails/routes/mlte/paths/24.pat"
[I] "c:/program files/open rails/routes/mlte/paths/24.pat"
[I] Nowy  36  path:  "c:/program files/open rails/routes/mlte/paths/256.pat"
[I] "c:/program files/open rails/routes/mlte/paths/256.pat"
[I] Nowy  37  path:  "c:/program files/open rails/routes/mlte/paths/26.pat"
[I] "c:/program files/open rails/routes/mlte/paths/26.pat"
[I] Nowy  38  path:  "c:/program files/open rails/routes/mlte/paths/269.pat"
[I] "c:/program files/open rails/routes/mlte/paths/269.pat"
[I] Nowy  39  path:  "c:/program files/open rails/routes/mlte/paths/27.pat"
[I] "c:/program files/open rails/routes/mlte/paths/27.pat"
[I] Nowy  40  path:  "c:/program files/open rails/routes/mlte/paths/274.pat"
[I] "c:/program files/open rails/routes/mlte/paths/274.pat"
[I] Nowy  41  path:  "c:/program files/open rails/routes/mlte/paths/344.pat"
[I] "c:/program files/open rails/routes/mlte/paths/344.pat"
[I] Nowy  42  path:  "c:/program files/open rails/routes/mlte/paths/346.pat"
[I] "c:/program files/open rails/routes/mlte/paths/346.pat"
[I] Nowy  43  path:  "c:/program files/open rails/routes/mlte/paths/348.pat"
[I] "c:/program files/open rails/routes/mlte/paths/348.pat"
[I] Nowy  44  path:  "c:/program files/open rails/routes/mlte/paths/349.pat"
[I] "c:/program files/open rails/routes/mlte/paths/349.pat"
[I] Nowy  45  path:  "c:/program files/open rails/routes/mlte/paths/350.pat"
[I] "c:/program files/open rails/routes/mlte/paths/350.pat"
[I] Nowy  46  path:  "c:/program files/open rails/routes/mlte/paths/351.pat"
[I] "c:/program files/open rails/routes/mlte/paths/351.pat"
[I] Nowy  47  path:  "c:/program files/open rails/routes/mlte/paths/353.pat"
[I] "c:/program files/open rails/routes/mlte/paths/353.pat"
[I] Nowy  48  path:  "c:/program files/open rails/routes/mlte/paths/358.pat"
[I] "c:/program files/open rails/routes/mlte/paths/358.pat"
[I] Nowy  49  path:  "c:/program files/open rails/routes/mlte/paths/360.pat"
[I] "c:/program files/open rails/routes/mlte/paths/360.pat"
[I] Nowy  50  path:  "c:/program files/open rails/routes/mlte/paths/363.pat"
[I] "c:/program files/open rails/routes/mlte/paths/363.pat"
[I] Nowy  51  path:  "c:/program files/open rails/routes/mlte/paths/364.pat"
[I] "c:/program files/open rails/routes/mlte/paths/364.pat"
[I] Nowy  52  path:  "c:/program files/open rails/routes/mlte/paths/376.pat"
[I] "c:/program files/open rails/routes/mlte/paths/376.pat"
[I] Nowy  53  path:  "c:/program files/open rails/routes/mlte/paths/384.pat"
[I] "c:/program files/open rails/routes/mlte/paths/384.pat"
[I] Nowy  54  path:  "c:/program files/open rails/routes/mlte/paths/398.pat"
[I] "c:/program files/open rails/routes/mlte/paths/398.pat"
[I] Nowy  55  path:  "c:/program files/open rails/routes/mlte/paths/400.pat"
[I] "c:/program files/open rails/routes/mlte/paths/400.pat"
[I] Nowy  56  path:  "c:/program files/open rails/routes/mlte/paths/403.pat"
[I] "c:/program files/open rails/routes/mlte/paths/403.pat"
[I] Nowy  57  path:  "c:/program files/open rails/routes/mlte/paths/404.pat"
[I] "c:/program files/open rails/routes/mlte/paths/404.pat"
[I] Nowy  58  path:  "c:/program files/open rails/routes/mlte/paths/408.pat"
[I] "c:/program files/open rails/routes/mlte/paths/408.pat"
[I] Nowy  59  path:  "c:/program files/open rails/routes/mlte/paths/413.pat"
[I] "c:/program files/open rails/routes/mlte/paths/413.pat"
[I] Nowy  60  path:  "c:/program files/open rails/routes/mlte/paths/418.pat"
[I] "c:/program files/open rails/routes/mlte/paths/418.pat"
[I] Nowy  61  path:  "c:/program files/open rails/routes/mlte/paths/420.pat"
[I] "c:/program files/open rails/routes/mlte/paths/420.pat"
[I] Nowy  62  path:  "c:/program files/open rails/routes/mlte/paths/427.pat"
[I] "c:/program files/open rails/routes/mlte/paths/427.pat"
[I] Nowy  63  path:  "c:/program files/open rails/routes/mlte/paths/429.pat"
[I] "c:/program files/open rails/routes/mlte/paths/429.pat"
[I] Nowy  64  path:  "c:/program files/open rails/routes/mlte/paths/431.pat"
[I] "c:/program files/open rails/routes/mlte/paths/431.pat"
[I] Nowy  65  path:  "c:/program files/open rails/routes/mlte/paths/433.pat"
[I] "c:/program files/open rails/routes/mlte/paths/433.pat"
[I] Nowy  66  path:  "c:/program files/open rails/routes/mlte/paths/52.pat"
[I] "c:/program files/open rails/routes/mlte/paths/52.pat"
[I] Nowy  67  path:  "c:/program files/open rails/routes/mlte/paths/53.pat"
[I] "c:/program files/open rails/routes/mlte/paths/53.pat"
[I] Nowy  68  path:  "c:/program files/open rails/routes/mlte/paths/54.pat"
[I] "c:/program files/open rails/routes/mlte/paths/54.pat"
[I] Nowy  69  path:  "c:/program files/open rails/routes/mlte/paths/60.pat"
[I] "c:/program files/open rails/routes/mlte/paths/60.pat"
[I] Nowy  70  path:  "c:/program files/open rails/routes/mlte/paths/64.pat"
[I] "c:/program files/open rails/routes/mlte/paths/64.pat"
[I] Nowy  71  path:  "c:/program files/open rails/routes/mlte/paths/72.pat"
[I] "c:/program files/open rails/routes/mlte/paths/72.pat"
[I] Nowy  72  path:  "c:/program files/open rails/routes/mlte/paths/83.pat"
[I] "c:/program files/open rails/routes/mlte/paths/83.pat"
[I] Nowy  73  path:  "c:/program files/open rails/routes/mlte/paths/90.pat"
[I] "c:/program files/open rails/routes/mlte/paths/90.pat"
[I] paths loaded
[I] "C:\\Program Files\\Open Rails/routes/MLte/ssource.dat"
[I] "C:\\Program Files\\Open Rails/routes/MLte/ttype.dat"
[I] "tdfile"   -21   24
[I] "tdfile"   -21   24
[I] "C:\\Program Files\\Open Rails/routes/MLte/weathertransitions.dat"
[I] "C:\\Program Files\\Open Rails/routes/MLte/forests.dat"
[I] "forest"
[I] "C:\\Program Files\\Open Rails/routes/MLte/carspawn.dat"
[I] "carspawneritem"
[I] "C:\\Program Files\\Open Rails/routes/MLte/openrails/carspawn.dat"
[I] Nowy  0  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/skydome.s"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589c0.t"
[I] # InitializeOpenGLFunctions
[I] # InitShaders
[I] Shader file not found  "tsre_appdata/0.697/shaders/StandardFog.vs"
[I] Shader file not found  "tsre_appdata/0.697/shaders/StandardFog.fs"
[E] QOpenGLShader::link: ERROR: Definition for "void main()" not found.
[I] Shader link failed.
[I] Shader bind failed.
[E] QOpenGLShaderProgram::uniformLocation( uPMatrix ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uFMatrix ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uShadowPMatrix ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uShadow2PMatrix ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uMVMatrix ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uMSMatrix ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( lod ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( sun ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( skyColor ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( isAlpha ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( alphaTest ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( textureEnabled ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shapeColor ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( enableNormals ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( diffuseColor ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( ambientColor ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( specularColor ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( lightDirection ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( secondTexEnabled ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadowsEnabled ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( colorBrightness ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( fogDensity ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadow1Res ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadow1Bias ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadow2Res ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadow2Bias ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uSampler ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( uSampler2 ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadow1 ): shader program is not linked
[E] QOpenGLShaderProgram::uniformLocation( shadow2 ): shader program is not linked
[I] Shader file not found  "tsre_appdata/0.697/shaders/StandardBloom.vs"
[I] Shader file not found  "tsre_appdata/0.697/shaders/StandardBloom.fs"
[I] Shader file not found  "tsre_appdata/0.697/shaders/Shadows.vs"
[I] Shader file not found  "tsre_appdata/0.697/shaders/Shadows.fs"
[I] # InitShaders finished
[I] "C:\\Program Files\\Open Rails/trains/consists/"
[I] 29  con files
[I] loaded
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a5893c.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a58938.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589c4.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589c8.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589cc.t"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010281+012714.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010281+012715.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010281+012716.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010280+012714.w"
[I] 435
[I] Nowy  1  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio3.s"
[I] Nowy  2  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio1.s"
[I] Nowy  3  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio5.s"
[I] Nowy  4  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio2.s"
[I] Nowy  5  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio4.s"
[I] Nowy  6  shape:  "C:/Program Files/Open Rails/global/shapes/A1t50mStrt.s"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010280+012715.w"
[I] 1509
[I] Nowy  7  shape:  "C:/Program Files/Open Rails/global/shapes/Road2L05deg.s"
[I] Nowy  8  shape:  "C:/Program Files/Open Rails/global/shapes/Road2L20deg.s"
[I] Nowy  9  shape:  "C:/Program Files/Open Rails/global/shapes/Road2LStrt10m.s"
[I] Nowy  10  shape:  "C:/Program Files/Open Rails/global/shapes/Road2LStrt60m.s"
[I] Nowy  11  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/ADJ.s"
[I] Nowy  12  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBuffer.s"
[I] Nowy  13  shape:  "C:/Program Files/Open Rails/global/shapes/A1t0_8mStrt.s"
[I] Nowy  14  shape:  "C:/Program Files/Open Rails/global/shapes/A1t10mStrt.s"
[I] Nowy  15  shape:  "C:/Program Files/Open Rails/global/shapes/A1tPnt4_7dRgt.s"
[I] Nowy  16  shape:  "C:/Program Files/Open Rails/global/shapes/A1tPnt4_7dLft.s"
[I] Nowy  17  shape:  "C:/Program Files/Open Rails/global/shapes/A1tEndPnt4_7d.s"
[I] Nowy  18  shape:  "C:/Program Files/Open Rails/global/shapes/A1tPnt7_5dLft.s"
[I] Nowy  19  shape:  "C:/Program Files/Open Rails/global/shapes/A1t5mStrt.s"
[I] Nowy  20  shape:  "C:/Program Files/Open Rails/global/shapes/A1t35mStrt.s"
[I] Nowy  21  shape:  "C:/Program Files/Open Rails/global/shapes/A1tPnt7_5dRgt.s"
[I] Nowy  22  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBrdg10mStrt.s"
[I] Nowy  23  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBrdg40mStrt.s"
[I] Nowy  24  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBrdg30mStrt.s"
[I] Nowy  25  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBrdg50mStrt.s"
[I] Nowy  26  shape:  "C:/Program Files/Open Rails/global/shapes/A1tEndPnt7_5d.s"
[I] Nowy  27  shape:  "C:/Program Files/Open Rails/global/shapes/A1t250mStrt.s"
[I] Nowy  28  shape:  "C:/Program Files/Open Rails/global/shapes/A1t100mStrt.s"
[I] Nowy  29  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VeMcs3LS.s"
[I] Nowy  30  shape:  "C:/Program Files/Open Rails/global/shapes/A1t30mStrt.s"
[I] Nowy  31  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/ADJ-T.s"
[I] Nowy  32  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/reja-rio.s"
[I] Nowy  33  shape:  "C:/Program Files/Open Rails/global/shapes/Road4LaneT.s"
[I] Nowy  34  shape:  "C:/Program Files/Open Rails/global/shapes/Road2L10deg.s"
[I] Nowy  35  shape:  "C:/Program Files/Open Rails/global/shapes/Road2L45deg.s"
[I] Nowy  36  shape:  "C:/Program Files/Open Rails/global/shapes/Road4LStrt150m.s"
[I] Nowy  37  shape:  "C:/Program Files/Open Rails/global/shapes/Road2LStrt100m.s"
[I] Nowy  38  shape:  "C:/Program Files/Open Rails/global/shapes/Road2LStrt20m.s"
[I] Nowy  39  shape:  "C:/Program Files/Open Rails/global/shapes/Road2LStrt40m.s"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010280+012716.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010279+012714.w"
[I] 4
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010279+012715.w"
[I] 2556
[I] Nowy  40  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/Guaire.s"
[I] Nowy  41  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/1t4m+C+A+B.s"
[I] Nowy  42  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/luces-doble.s"
[I] Nowy  43  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/TUN-TRIN-RUI.s"
[I] Nowy  44  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/RuizPineda-Interno.s"
[I] Nowy  45  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/RuizPineda-Externo.s"
[I] Nowy  46  shape:  "C:/Program Files/Open Rails/global/shapes/A1t25mStrt.s"
[I] Nowy  47  shape:  "C:/Program Files/Open Rails/global/shapes/A1t150mStrt.s"
[I] Nowy  48  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VeMcs1PDE.s"
[I] Nowy  49  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VeMcs2LS.s"
[I] Nowy  50  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBrdg100mStrt.s"
[I] Nowy  51  shape:  "C:/Program Files/Open Rails/global/shapes/A1t90mStrt.s"
[I] Nowy  52  shape:  "C:/Program Files/Open Rails/global/shapes/A1tBrdg75mStrt.s"
[I] Nowy  53  shape:  "C:/Program Files/Open Rails/global/shapes/A1t15mStrt.s"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010279+012716.w"
[I] 301
[I] Nowy  54  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/1t4m+B.s"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/1t4m+C+A+B.sd"
[I] S Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/skydome.s"
[I] 501128
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/lo_tiles/-07a588.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/lo_tiles/-07a59c.t"
[I] 501124
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/lo_tiles/-07a584.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/lo_tiles/-07a590.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a5892c.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589d0.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589dc.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a58934.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a58920.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a58924.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a58928.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589d4.t"
[I] T File  "C:\\Program Files\\Open Rails/routes/MLte/tiles/-07a589d8.t"
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010282+012713.w"
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010282+012714.w"
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010282+012715.w"
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010282+012716.w"
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010282+012717.w"
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010281+012713.w"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010281+012717.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010280+012713.w"
[I] 0
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio3.sd"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio2.sd"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio5.sd"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio4.sd"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/barrio1.sd"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010280+012717.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010279+012713.w"
[I] 0
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/1t4m+B.sd"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010279+012717.w"
[I] 0
[I] W file: not exist  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010278+012713.w"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010278+012714.w"
[I] 0
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010278+012715.w"
[I] 2440
[I] Nowy  55  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/1t4m+A+B.s"
[I] Nowy  56  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-REJA-SUPERIOR.s"
[I] Nowy  57  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-REJA-INFERIOR.s"
[I] Nowy  58  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-BASE-PILOTE.s"
[I] Nowy  59  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-BASE.s"
[I] Nowy  60  shape:  "C:/Program Files/Open Rails/global/shapes/A1t60mStrt.s"
[I] Nowy  61  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/CRC.s"
[I] Nowy  62  shape:  "C:/Program Files/Open Rails/global/shapes/A1t40mStrt.s"
[I] Nowy  63  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-PILOTE.s"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-REJA-SUPERIOR.sd"
[I] Sd Shape: not exist  "C:/Program Files/Open Rails/routes/MLte/shapes/VIA-ZOO-CRC-REJA-INFERIOR.sd"
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010278+012716.w"
[I] 1670
[I] Nowy  64  shape:  "C:/Program Files/Open Rails/global/shapes/A1t20mStrt.s"
[I] Nowy  65  shape:  "C:/Program Files/Open Rails/global/shapes/A1tPnt500r8dLft.s"
[I] signal fail nid
[I] w file uncompressed  "C:\\Program Files\\Open Rails/routes/MLte/world/w-010278+012717.w"
[I] 484
[I] Nowy  66  shape:  "C:/Program Files/Open Rails/global/shapes/A1t200mStrt.s"
[I] Nowy  67  shape:  "C:/Program Files/Open Rails/routes/MLte/shapes/Mamera.s"
[E] setGeometry: Unable to set geometry 1280x800+8+31 on QWidgetWindow/'RouteEditorWindowClassWindow'. Resulting geometry:  1280x749+8+31 (frame: 8, 31, 8, 8, custom margin: 0, 0, 0, 0, minimum size: 466x670, maximum size: 16777215x16777215).
[I] = release terrain  1
[I] = release terrain  0
system specs
system specs
Capture of the issue
WhatsApp Image 2020-12-18 at 9.23.30 PM.jpeg (37.32 KiB) Viewed 20861 times
Opengl is not installed.
Switch Tender
With only 2GB of RAM you're not going to have a good experience trying to use TSRE on this laptop, if it works at all.
Keep that in mind.
