Crating Tunnel
Can Anyone Plz Explain Me The Process of Making Tunnels Using Tsre ?
Plz See Attachments If I fill Gaps Then They are filling Tunnels Also plz guide me
- Attachments
- IMG_20200521_233626.jpg (5.42 MiB) Viewed 15007 times
- IMG_20200521_233619.jpg (4.53 MiB) Viewed 15007 times
You have to cover these gaps with transfer objects.
Or shapes/vegetation.
ok , Thank you Sir
Refer The Photo Attached with the Reply This is the condition After Decreasing Hight Of Terrain For Construction of Bridge .
Plz Guide me What to do Now ?
- Attachments
- IMG_20200523_195256.jpg (4.21 MiB) Viewed 14936 times
Disable distant terrain (DM) if you don't use real terrain height data.
But I am Using real Terrain Data sir
It doesn't look like. But if you are, switch to distant terrain editing and modify the distant terrain so it can match your detailed terrain.
