Tools windows error
Jose Manuel
Version 0.697 does not start the tools windows correctly.
Initially they are located extremely high and to the left of the desktop, which prevents them from being moved by the user.
To offer some more information just in case someone suffers the same problem I will say that I work with two monitors and with the option of floating tools: mainWindowLayout = W
I attach an image showing the problem...
Jose Manuel Genzor
Zaragoza - Spain
Jose Manuel
I have found a temporary solution to the problem:
If the tool window is selected and resized, it returns to a normal position within the desktop.
Jose Manuel Genzor
Zaragoza - Spain
xavivilla
The same trick I use. I select the lower part of the window, I stretch it a little bit downwards and the top bar of the window is repositioned to be able to drag it to the second monitor.
I apologize for my English of translator
Jose Manuel
xavivilla wrote: 25 Jan 2019, 21:27 The same trick I use. I select the lower part of the window, I stretch it a little bit downwards and the top bar of the window is repositioned to be able to drag it to the second monitor.
Hi Javi, I'm very happy to see you here ...
Jose Manuel Genzor
Zaragoza - Spain
