Running 0.6972.
Finding if I hold down the RMB to change viewpoint while navigating, on release it always opens the pop up contextual menu. This is annoying as you need to click outside the Editor window to get rid of it.
Although I've got sticky keys disabled in Win 10 I'm finding the camera will start moving on its own across and under the terrain if I make more than a couple of directional key presses - with or without Shift and RMB. It is very difficult to stop the motion - pressing a key in the opposite direction does not arrest it.
						Two Navigation Issues
No. When you move using RMB, there is no context menu. Context menu appears only if you press and release mouse without moving it.
For me works good. But if camera starts moving on it's own, you have to press the same direction, not opposite.OldVern wrote: ↑03 Mar 2019, 20:08Although I've got sticky keys disabled in Win 10 I'm finding the camera will start moving on its own across and under the terrain if I make more than a couple of directional key presses - with or without Shift and RMB. It is very difficult to stop the motion - pressing a key in the opposite direction does not arrest it.
Your problems look like problems with window focus, but I have no idea why. For others it is fine.
