Fine Line Painting
DukeHB
Hello,
the painting functions are great. With the ruler there are class possibilities. Roads, for example, can be designed flexibly.
But if you want to draw fine lines, you won't get a solid line with the ruler.
Maybe I think wrong, but can you do that?
Duke
Indeed you can't get a fine line because TSRE uses huge step value when painting lines.
I will try to find a solution.
