Deleting TDBItems
vince
When an orphan TDBItem icon is selected, with no shape in W, and then deleted could you explain what files are altered. eg the W, tit & tdb datablocks?
Example: A user has found a 'phantom' signal object; It shows in track monitor but no world file shape.
If you could take the time exactly what datablocks are altered or removed I would give me a comfortable feeling.
And also here to thank you for TSRE. It certainly proved itself and your concept in the modding of the PRR East.
regards,
vince
Only TDB files are altered. Remove these items carefully, because it can destroy the route.
This option should be used only for fixing broken route / objects.
