Object Placement Problem
cyrail
Hi
Been trying to spruce up a old a couple for old routes out of the F/L. One is the Chippewau sub. Trying to place some trees with TSRE v.0697.
I save route , but when I go to run route I get the following : "Open Rails detected a track section which is not present in tsection.data and cannot continue.
Most likely you don't have the XTracks or Ytracks version needed for this route."
From the Open Rails log I pasted the following section:
Loading TRK TDB SIGCFG DAT
Warning: Skipped track section 574 not in global or dynamic TSECTION.DAT
Warning: Skipped track section 542 not in global or dynamic TSECTION.DAT
Warning: Skipped track section 544 not in global or dynamic TSECTION.DAT
Warning: Skipped track section 566 not in global or dynamic TSECTION.DAT
Warning: Skipped track section 568 not in global or dynamic TSECTION.DAT
ACT RDB CARSPAWN SIGSCR
Any thoughts on what is going on would be appreciated
Mark
Old routes are usually out of sync with your current global Tsection.dat file.
Update the route to current Tsection.dat before editing in TSRE or disable TDB editing in settings.txt.
Otherwise TSRE will destroy the route track database.
cyrail
Thanks Goku. I had forgotten about that line TDB in settings.txt
Mark
