Page 9 of 10
Re: Multiplayer Editing Demo
Posted: 12 Jan 2022, 22:38
by Louis
A bug appeared that a section of rails was missing. It was originally, this problem is fixed only for one user, the second has a section. I am attaching screenshots from two screens.
Player1 -
https://prnt.sc/26cyo37
Player2 -
https://prnt.sc/26cylb3
After Player2 switched, the vector glitched. -
https://prnt.sc/26cyox8
After restarting the server, the vectors at part of the station got bugged -
https://prnt.sc/26cypgu
Posted: 13 Jan 2022, 13:29
by Louis
Desynced when changing the type of land. They made a hill and leveled it back, it leveled off for one user, and remained the same for the second.
Player 1 who was removed and lost
https://cdn.discordapp.com/attachments/ ... nknown.png
Player 2, who had a desynchronization, is also the second Player 1, who is standing still, but in fact he is building paths who had a desync
https://prnt.sc/26d70db
After 4 minutes, Player 2 synchronized and the mountain leveled out and Player 1 began to move and what he did was drawn
Also, if the characters ASCII in the login use in the login does not work
Posted: 13 Jan 2022, 15:05
Louis wrote: ↑13 Jan 2022, 13:29
Are your settings.txt and users.txt set to utf8? I did try russian names and it worked great.
You can't use space, = , : , @ .
Posted: 13 Jan 2022, 15:08
Sending heightmap data changes takes very long. If two users edit the same tile terrain at the same time, it can cause problems.
Posted: 13 Jan 2022, 15:50
by Louis
Goku wrote: ↑13 Jan 2022, 15:05
I understood about the tile, but about the fact that we have a problem with the paths that I wrote about above.
Posted: 13 Jan 2022, 15:51
by Louis
I'll check, well, in general, UTF8
by Louis
Did you receive my message in the mail that I wrote to you about cooperation?
Posted: 13 Jan 2022, 16:21
Yes. I did send you short reply.
Posted: 13 Jan 2022, 16:24
Louis wrote: ↑13 Jan 2022, 15:50I understood about the tile, but about the fact that we have a problem with the paths that I wrote about above.
Check last sentence of this post:
viewtopic.php?p=1249#p1249
Maybe it is it? I don't know. It is a more difficult thing to solve.
Posted: 13 Jan 2022, 16:25
Louis wrote: ↑13 Jan 2022, 15:51I'll check, well, in general, UTF8
Then, can you show me an example that doesn't work?
