Multiplayer Editing Demo
Louis
A bug appeared that a section of rails was missing. It was originally, this problem is fixed only for one user, the second has a section. I am attaching screenshots from two screens.
Player1 - https://prnt.sc/26cyo37
Player2 - https://prnt.sc/26cylb3
After Player2 switched, the vector glitched. - https://prnt.sc/26cyox8
After restarting the server, the vectors at part of the station got bugged - https://prnt.sc/26cypgu
Louis
Desynced when changing the type of land. They made a hill and leveled it back, it leveled off for one user, and remained the same for the second.
Player 1 who was removed and lost https://cdn.discordapp.com/attachments/ ... nknown.png
Player 2, who had a desynchronization, is also the second Player 1, who is standing still, but in fact he is building paths who had a desync https://prnt.sc/26d70db
After 4 minutes, Player 2 synchronized and the mountain leveled out and Player 1 began to move and what he did was drawn
Also, if the characters ASCII in the login use in the login does not work
Louis wrote: 13 Jan 2022, 13:29 Also, if the characters ASCII in the login use in the login does not work
Are your settings.txt and users.txt set to utf8? I did try russian names and it worked great.
You can't use space, = , : , @ .
Louis wrote: 13 Jan 2022, 13:29 Desynced when changing the type of land. They made a hill and leveled it back, it leveled off for one user, and remained the same for the second.
Sending heightmap data changes takes very long. If two users edit the same tile terrain at the same time, it can cause problems.
Louis
Goku wrote: 13 Jan 2022, 15:05
I understood about the tile, but about the fact that we have a problem with the paths that I wrote about above.
Louis
I'll check, well, in general, UTF8
Louis
Did you receive my message in the mail that I wrote to you about cooperation?
Yes. I did send you short reply.
Louis wrote: 13 Jan 2022, 15:50I understood about the tile, but about the fact that we have a problem with the paths that I wrote about above.
Check last sentence of this post:
viewtopic.php?p=1249#p1249
Maybe it is it? I don't know. It is a more difficult thing to solve.
Louis wrote: 13 Jan 2022, 15:51I'll check, well, in general, UTF8
Then, can you show me an example that doesn't work?
