Distant Mountains
Hi Goku
Would it be possible to make an "Auto Tile Generation" feature for Distant Mountains?
This feature for standard terrain -- check 2 boxes and move over the empty tile -- is so easy to use.
You can auto generate DM using TDB or MKR files.
When I click the "Generate tiles using MKR/TDB" buttons, I get a totally flat tile generated at zero altitude.
Then I click "Load Height" button, and click on the tile, a new Tile window opens, and I click the header "Load". Finally I close this window and the height is added to the tile in my route.
For standard terrain it is so simple. Check 2 boxes and move over the tile to be created. It appears. So easy!
Just check the box for auto terran heightmap before making DM using MKR/TDB.
Wonderful!!!
