When I lay a dynamic track I can change the gradient of the track using the rotation tool. This would be fine when handling large gradients, however, I have a case where I should have about 5 promille of gradient in the track which I can't blur out somewhere else.
I tried to edit the gradient of the dynamic track via the (in most cases excellent) gradient tool in TSRE, but when I try to enter a precise gradient there, TSRE crashes to desktop.
Is this intended behaviour, is there something I might be doing wrong, or have I actually found a bug?
Robert
Precise gradient in dynamic tracks
Yes , TSRE Crashes while Adjusting The Elevation Of Dynamic Tracks , Plz Solve this issue as fast as possible
