Hello,
it is not possible to put new terrain textures in versions 0.698 and 0.6981.
Neither in put- nor in paint mode the textures can be applied or changed.
Without these features, the new version of TSRE is pretty worthless for me at the moment; I must and will therefore continue to work with version 0.6976, as this version runs without major bugs.
Best regards
Richie
Terrtex bug
Works for me.
Are you sure that you didn't set custom season by mistake in settings.txt?
Hello Goku!
I can't understand what you mean!
In my Settings.txt I have the following entry:
seasonal terrtex
seasonalEditing = true
season = "winter"
Is there something missing or is something wrong? I don't know.
An updated and more extensively documented manual for the individual instructions in Settings.txt would be desirable and helpful.
Best regards
Richie
seasonal terrtex
season = "winter"
Best regards
Richie
Yes, it is wrong. You have set your season to winter. In other seasons than default, you can't edit terrain shaders. Only repaint painted textures.
Set seasonalEditing to false or disable your season = winter settings by commenting it using #.
