Page 2 of 2
Re: Consist editor problem.
Posted: 09 Apr 2020, 05:59
by Bloodonfire3
I too am having issues with the Consist Editor. I just dropped a repainted locomotive into my Trainset folder, and wanted to test it out. I checked on here for a solution, but after removing several consists and activities that had non-existent rolling stock, the editor will not load. It starts, after I click load, it just stops. I've tried as many ways to try to rectify this as I can, but I'm at a loss.
Posted: 09 Apr 2020, 08:33
Loot at last log line, there is a file path causing a problem:
"g:/hjellum games/orts/1-fictional/train simulator/routes/fblinecomm/activities/fb_ba_goodoldtimes.act"
converting to UTF16
Posted: 09 Apr 2020, 19:11
by Bloodonfire3
Thank you, Goku. I moved the activities out of the main folder, and it worked. So note to anybody else: check all your routes for activities, because for some reason, there appears to be a glitch between MSTS activites for older routes. This is my observation, not meant to criticize.
Posted: 23 May 2020, 18:33
by xavivilla
Hello
I have a friend who, when correcting a broken consists, the consists editor crashes. Sometimes it manages to repair one and the next time the program fails, sometimes not even that. Attached file 'Log.txt'
thanks for your help
