Consist editor problem.
Bloodonfire3
I too am having issues with the Consist Editor. I just dropped a repainted locomotive into my Trainset folder, and wanted to test it out. I checked on here for a solution, but after removing several consists and activities that had non-existent rolling stock, the editor will not load. It starts, after I click load, it just stops. I've tried as many ways to try to rectify this as I can, but I'm at a loss.
log.zip
(34.42 KiB) Downloaded 429 times
Loot at last log line, there is a file path causing a problem:
"g:/hjellum games/orts/1-fictional/train simulator/routes/fblinecomm/activities/fb_ba_goodoldtimes.act"
converting to UTF16
Bloodonfire3
Thank you, Goku. I moved the activities out of the main folder, and it worked. So note to anybody else: check all your routes for activities, because for some reason, there appears to be a glitch between MSTS activites for older routes. This is my observation, not meant to criticize.
xavivilla
Hello
I have a friend who, when correcting a broken consists, the consists editor crashes. Sometimes it manages to repair one and the next time the program fails, sometimes not even that. Attached file 'Log.txt'
thanks for your help
log.rar
(183.9 KiB) Downloaded 398 times
I apologize for my English of translator
