Multiplayer Editing Demo
Louis
Goku wrote: 13 Jan 2022, 16:25
Louis wrote: 13 Jan 2022, 15:51I'll check, well, in general, UTF8
Then, can you show me an example that doesn't work?
Slavka_NVKZ
For example, here is a login
https://prnt.sc/26d9kxe
Louis
Goku wrote: 13 Jan 2022, 16:24
Louis wrote: 13 Jan 2022, 15:50I understood about the tile, but about the fact that we have a problem with the paths that I wrote about above.
Check last sentence of this post:
viewtopic.php?p=1249#p1249
Maybe it is it? I don't know. It is a more difficult thing to solve.
Yes, it turns out that the desynchronization, the vector remain, and the rails disappear, can you try to get some logs?
Louis
Goku wrote: 13 Jan 2022, 16:21 Yes. I did send you short reply.
Ah, I saw it. And a more accurate answer after about how long it will be possible to find out, this is very important) Also, for your convenience, in what language do you write?
To find out what?
Louis
Goku wrote: 13 Jan 2022, 18:02To find out what?
Reply to my letter. Did you unsubscribe once? (Thank you for your email.) Is your answer? Am I wrong mail?
starski80
hello goku I entered the parameters as [attachment=0]settings.zip[/attachment you wrote but it does not connect to me and the editor does not open, can you explain to me?
Immagine 2022-01-27 175413.jpg (28.85 KiB) Viewed 434900 times
settings.zip
(1017 Bytes) Downloaded 4891 times
Switch Tender
You're missing a space between = and D.
Otherwise looks fine.
try this
starski80
hello thank you for the answer, I tried your solution but nothing changes it does not connect me. i don't know how to fix
