Louis
Posts: 53 Joined: 09 Jan 2022, 11:33
Goku wrote: ↑13 Jan 2022, 16:25
Louis wrote: ↑13 Jan 2022, 15:51I'll check, well, in general, UTF8
Then, can you show me an example that doesn't work?
Slavka_NVKZ
For example, here is a login
https://prnt.sc/26d9kxe
Louis
Goku wrote: ↑13 Jan 2022, 16:24
Louis wrote: ↑13 Jan 2022, 15:50I understood about the tile, but about the fact that we have a problem with the paths that I wrote about above.
Check last sentence of this post:
viewtopic.php?p=1249#p1249
Maybe it is it? I don't know. It is a more difficult thing to solve.
Yes, it turns out that the desynchronization, the vector remain, and the rails disappear, can you try to get some logs?
Louis
Goku wrote: ↑13 Jan 2022, 16:21
Yes. I did send you short reply.
Ah, I saw it. And a more accurate answer after about how long it will be possible to find out, this is very important) Also, for your convenience, in what language do you write?
Posts: 364 Joined: 15 Jan 2019, 18:10
Louis
Goku wrote: ↑13 Jan 2022, 18:02To find out what?
Reply to my letter. Did you unsubscribe once? (Thank you for your email.) Is your answer? Am I wrong mail?
starski80
Posts: 2 Joined: 27 Jan 2022, 16:09
hello goku I entered the parameters as [attachment=0]settings.zip[/attachment you wrote but it does not connect to me and the editor does not open, can you explain to me?
- Immagine 2022-01-27 175413.jpg (28.85 KiB) Viewed 425926 times
- settings.zip
- (1017 Bytes) Downloaded 4773 times
Switch Tender
Posts: 37 Joined: 17 Jan 2019, 01:58
You're missing a space between = and D.
Otherwise looks fine.
try this
starski80
hello thank you for the answer, I tried your solution but nothing changes it does not connect me. i don't know how to fix
