Dynamic track with odd sections
krausjxotv
Checking the CNW route found dynamic track with odd section numbers.
---> 'TrackPath(40010-1)': Section-Reference is NOT an even number! (40035)
TrackSection (
SectionCurve ( 1 ) 40034 -0.29 100
TrackSection (
SectionCurve ( 1 ) 40035 0.29 100
TrackPath ( 40010 2 40032 40035 )
Curved sections are defined as an even number followed by an odd number. The TrackPath should use the even number.
TrackPath ( 40010 2 40032 40034 )
Route from http://www.digitalrails.com/2021/02/cnw ... route.html
TSRE allows to place positive angle dynamic tracks. In this case an uneven number is used.
It works fine in MSTS and OR.
Your database checking tool is outdated and wrong.
Yeah, not only is Jeffrey's tool wrong, it's throwing an error over a SectionIdx that isn't even in use.
There should be zero pieces of dynamic track in use on that route.
You can read about positive angle dynamic tracks here:
http://www.elvastower.com/forums/index. ... der-wrong/
